Hello all,
I don’t know if this is documented but I noticed the values for HDR can be VERY SMALL.
Like Skylight and Background values of 0.001
The problem is, in all cases under 0.1 become 0
When I type .01 I realised the skylight was dimmer than 0.1 so I tried typing 0.001 and it worked. Most of times, an HDRI sky is too bright for nightscenes (at least, compared to the spot lights ranges) so I need to tone down the skies and was bothered by the fact that D5 seemed not to cope with small values.
BUT it can.
I already requested more control over HDRI power but now I also ask for more numerals after the comma ![]()
Thank you for your feedback, we will adjust the HDRI Sky Brightness parameter to display three decimal places in the next version.
please consider doing so with every parameter where we have to deal with precise inputs (like texture offset) or small numbers (scaling, …)
Input values - Ideas & Requests - D5 RENDER FORUM
