It would be very useful to have a tool to make a green wall like Lumion.
Hello, the hedge tool of D5 2.4 version can help you make green walls, you can try this function. Under the category of hedge in the assets library, select the model whose name contains “single series”. Using the Brush tool, set the Radius parameter to its maximum value to activate the Scatter tool. Adjust the Density parameter and select “Align to Terrain”.
It helps, but having a green wall tool like Lumion helps a lot.
