It would be great to have effect when fog color will affect Sky GI color casting. Currently fog has no effect to that - fog color is only visible in reflections but it doesn’t have real impact on GI. Objects are still “colored” by pure blue sky.
With the volume light enabled, the fog color should start influencing the Sky GI color casting.
Could you check if that gives the effect you’re looking for?
Thank you for give solution. Yes it works well. It give GI color cast. But little less noticeable than reflection colors. It would be great to have some parameters to change default sky color tint.
