Floating plants animation
Hi Guys,
Recently I was trying to make a floating lotus on water and was unable to make it. :confused: :
I want to understand how to make a floating object on water with D5.
I used a plane and applied water material to it.
Any tutorial or advice would be of great help.
D5_Clip 1_20231106_135849
Hi, can you describe more details about the floating object? Maybe there is a slight dynamic effect in the animation?
if you see video sample the plant is not floating on water, plant is still white the water is moving. I want the Lotus to float on the water with the flow. like a paper floats on water.
Hope I am able to describe the scene :slight_smile:
Thanks for your advice. I will convey your requirement to our team.
And maybe you can try this one.
