Hi Team, I am facing a problem while using D5 for animation render sequences. In my render sequences these is some unwanted ghost trails and very much flickering in close distance objects, in balcony there is very much flicker in balcony railings and top terrace bars, I am facing this problem since using D5 render. Please help me to resolve this. I have to submit a project on very strict deadlines, but my client will never accept this kind of video. I am attaching here my images
It’s best to generate a link containing the video animation so we can check it.
Anyway, we’ve received similar reports about the issues that you’re experiencing.
Ghost Trails - Try to disable Cloud or Super Resolution, then try to render again and see if the issue persists.
Screen Flicker - if the flicker is only seen in elements such as lattices or any vertical that may resemble a lattice, this is currently a known issue. Because of perspective, a single pixel can cover many objects when viewed from a great distance, but since each frame can only represent one colour, the objects depicted in the current frame may differ significantly from those drawn in the previous frame, thus creating this issue. How to Fix Low Resolution and Alpha Mask Flickering Issues in D5 Render 4K Output? - #10 by Clov
