[Fixed] RTX 5000 Series with NVIDIA Driver 576.02
I have the latest drivers on my 5090. the bug is still here:
thank you for testing and letting us know that the new 576.26 driver is also not good.
hope Nvidia picks this fast up
3 posts were split to a new topic: Darker Shadows
Hi @maher.nehme
We’ve tested three versions ofthe NVIDIA Graphics Card, which still have this problem:
  • Version 576.02
  • Version 576.28
  • Version 576.40
We suggest reverting back to drivers that is before 576.02, such as 572.47 or 572.83
Still not fixed with driver 576.52 from 19th of May.
As the problem been reported to D5 and Nvidia in some way?
Hi @pierre.romani.1
Yes, our team is aware of the issue and we have also contacted NVIDIA regarding this too. Thank you.
Same result here, I ve tested the new Nvidea driver 576.52 May 19th 2025 Studio driver and also game ready driver. Both drivers continue to show the dark patches, lines areas. Looking forward to a total solution soon.
Having the same problem
Thought my new 5080 was broken! Glad its just the driver, will try downgrade latest driver to resolve thankyou.
Hi everyone,
This issue will be addressed in the next version of D5 Render. Thank you to everyone who has reported, confirmed, and tested this issue.
Hello Clov,
Thank you for informing us. Any approximate ETA for the next version? I need to know if I need to modify all my textures or if I can just wait the fix.
Thanks
Hi @pierre.romani.1
I apologize but we can’t reveal any dates regarding the next version’s release as it may change depending on the results and feedbacks of the test. Thank you for your understanding.
New Nvidia drivers out yesterday, did they resolve the issue? Staying on old drivers is causing problems for me on other software now.
Hi @cadmunkey
This issue will be fixed in the next 2.11 update, it is still in beta test and official release may be around the corner.
  • Which Driver version are you currently running? 572.83 should be stable, I recommend using it.
Yes I am using 572.83, but as I said it is causing small problems in other software I use. Hopefully 2.11 is just around the corner :slight_smile:
Now that 2.11 is out, is the newest Nvidia driver good with RTX 5090?
Hi @bcsadmin
Yes, you can now install the new nvidia driver, the round corner should be fixed with the new 2.11 release.
going back to 2.10. I’m frustrated I now have to roll back to a previous Nvidia Driver, too.
https://forum.d5render.com/t/dont-install-2-11-its-a-mess/60355/3
with 2.11 update is this now fixed? can i update my driver?
@Clov
Hi @3d-ontwerp-visualisa
This issue has been fixed in the 2.11.0 Update.
