D5 Render Version:
Future update can add a finalize scatter option. As each time we open the file. The scatter changes form/shape from previous. So the landscape design changes and varies from file which was worked on 1 week ago. Can you please add a way that we dont get these changes each time we open a file. Even if it means that the main file has been changes. For example i meant that if we made changes in the sketchup file adding more area for that scatter we had used. Even if we had already finalized the previous scatter. We can definitely remove it and reapply it again.
Each time the file is opened again the scatter has to be regenerated. To make the process feel less tedious since i use like 20-30scatters on a project. And each time i open it i need to regen each scatter and so sitting and regen each statter itself takess like a good 1hour doing so even on a i9-13th gen and 4090 system. Cant even imagin what people would be going thru with lower based system.
