Export from revit only modified selected elements
From a very large model, select and export only some elements, so that those elements are modified in the D5 file.
Only those objects are modified in the D5 file.
This would improve the workflow, since the entire model is not reloaded, only the objects that the user selects.
So a modified object can be changed much faster on the D5.
