Experimenting with syncying multiple skp models in one D5 file
Hey everyone,
As the title says, I’m experimenting with syncing multiple models into a single D5 file, but I’ve run into an issue and was wondering if there’s any workaround for it.
I’m working on an interior design project with multiple rooms in the same house, and I want to model them separately in SketchUp. When everything is in a single SKP file, it gets very laggy, as usual.
At first, I tried doing this directly in SketchUp by saving each room (e.g. Master Suite, Kitchen, Bathroom, etc.) as a component, then using Save As to work on each room in separate files and reloading them into the master file. That approach didn’t work very well, since reloading each file after finishing it took a very long time.
So then I thought about handling this directly in D5: opening a master D5 file and syncing the individual room models into it.
This mostly works, except for one issue. When I import or sync the room files, D5 doesn’t retain the material settings I previously set up in the master file.
For example, a material named “00 – White Wall”, which already has its PBR textures correctly set up in the master scene, comes in without any settings applied — as if I were opening a brand-new D5 file.
I was wondering if anyone has run into this problem before or knows of a workaround to make D5 reuse existing materials instead of resetting them.
Here’s a mock image to make it easier to understand the issue:
Hi @gabrielporfiriorp
Thank you for explaining your workflow so clearly. What you’re experiencing is expected behavior in D5 Render. Even if the material name is identical (e.g., “00 – White Wall”), D5 treats materials from different SketchUp files as separate instances. Since they come from different source files, D5 does not automatically reuse the edited PBR settings from your master scene.
At the moment, D5 does not merge materials based only on matching names.
Please try these possible workarounds:
  1. Create one SKP file that already contains all your finalized materials. Start each room file from this template and reuse those materials instead of recreating them. This improves consistency.
  2. After syncing a room file, you can manually replace the newly imported material with the already-edited master material inside D5.
  3. Avoid recreating materials from scratch in each file if possible.
