so let me paint a picture, you choose a view, you need tons of clipping, you need a very low FOV, two point perspective, and a deep focus. now, every time you go to the scene and want to walk away, the scene will looked teared apart, since all the camera settings are extremely bad for walkthrough in general, because it’s all only good for that specific scene.
before, I would say, nah, it’s just me, maybe you want the settings be like that, but now we have two camera settings, one, the usual next to display and two, the one showing up at right panel when you press at the little camera. and, it now supports Aspect ratio, so when you walk out of the scene, the aspect ratio goes back to default, unless you are in editing mode.
so now I want to suggest the FOV, Focus and Clipping and perspective settings that shows up at right panel when you press at the little camera, would act like the aspect ratio, and only be active when I’m checking the scene or when I’m in editing mode. this way, when I go to a scene with clipping mask and etc, and I fly away, I don’t actually have to turn the settings off. it will be automatic, just like Aspect Ratio.
and if someone doesn’t like this, it’s just ok, they can use the regular camera settings next to display settings and use update scene like old times, but the settings on right panel, would be exclusive for camera.
this will enhance working experience a LOT.
