Disable toolbar
How do I disable the toolbar? I move it and remove it, but when I restart it, a huge horizontal bar is taking up space all by itself. Is there any way to remove it permanently or to permanently anchor it somewhere else?
It’s horrible
Hi there, sorry for the inconvenience. Can you provide screenshots of this issue so we can help you better? Thank you so much~
It is impossible to place the bar here, every time I start the bar is in that place
Please fix this, I don’t want the bar there and all that empty space.
It happens with D5_Live_Sync_3DsMax and with D5_Sync_3DsMax. I really don’t know what the difference is, I don’t understand why there are two plugins.
Hi there. I apologize for the inconvenience caused. The LiveSync plugin allows real-time synchronization of views between workflows, and any modifications you make to the model are directly reflected to D5 Render.
On the other hand, when using the Sync plugin, the model in D5 will remain consistent with its state at the start of synchronization, and any modification made in the model needs to be updated through the sync button.
As for the Livesync location in the toolbar, users cannot change the location permanently. You can drag it to the side where you want it to be situated, but it will revert to its original location whenever Max is closed. We are considering this feature wherein users can modify its location without reverting, perhaps in subsequent releases. Thank you for your understanding and insights regarding this matter.
Please, add the possibility to change the position permanently, workspace is lost just to have 8 icons, when you could have 70 (on my 4k screen).
The truth is that it is very annoying to see that wasted space all the time
Interesting statement because when i first had the D5 toolbar in Max, it was located in the upper left but only half of the toolbar was displayed. I moved it down a level and it now shows all the buttons. It has never moved from the relocated position.
he is not talking a specific icon in the toolbar, is the whole livesync toolbar that needs to have user controlo, to turn off, relocate and stay there, and consider small icons too.
