DAE and/or STL File Support
Is there an update on D5 excepting DAE and/or STL files? We recently purchased D5 but ran into an issue with our “work around” since these two formats are not excepted yet. Would really like to use this full time but it doesn’t work with our current workflow. Thank you!
There is an easy workaround that takes less than 2 minutes once you’ve done it more than once. Check it out here https://youtu.be/YJ2SQgEm5lE
Did they recently update something? Because before, if I reuploaded the FBX file, all my previously set D5 materials would reset.
