D5 x Stable Diffusion
Level up your rendering with Stable Diffusion.
I hope D5 team will consider about this feature !1
6ff02c187089813.65817ab2b71e1
494a2f187089813.65817ab2b8635
Hi junphuc17945.
This is an interesting idea, but you’re in the wrong area to post it, this goes to the idea being proposed. I don’t know if Team D5 will see it, I hope so, because like Blender, which is totally free, it has several plugins, which make the difference in the creation and design. D5 should make sure with the updates to divide them into plugins, that is, have a separation between the rendering program and its multiple functions, it would have an advantage, in my opinion, that I am not anyone but an ordinary user, that is, they would know what is bothering in the program and intervene immediately. But that’s another story.
Merry Christmas
this looks incredible. can you share how you did this? I love this!
Amazing…
If you can share your workflow…
Thank you
This is amazing! it will be great if you can please share how you got those results! and the workflow you have used.
Thank you very much in advance!
I found a video on youtube. this is an AI called Krea AI. watch This video to learn how to use it. the video is not english, but it’s easy to follow.
You could post how you did that!
Basta andare su KREA.
https://www.krea.ai/home
Ti devi aprire un link, poi basta vedere su YouTube come funziona e semplicissimo. ti metto un immagine fatta da me, è trasformata con Krea che è un inteligenza artificiale
Questa è fatta da Me
Questa invece è fatta da Krea
Invece con personaggi questa e fatta da me inserendo un immagine fotografica di una cucina di un ristorante
Invece questa e fatta da Krea
I guess to ‘cat is out the bag’ now with Krea. Hardly usable anymore. Looking for other options.
2024-02-01_17-08-35
Hi marcel, if you find difficulty with Krea, and you use the SketchUp program, there is a plugin called sketchup diffusion, I’ll put you a video that gives you some clarifications
Then I posted a test image in the gallery, first I had placed it normally then later with Krea modification, you will notice the difference.
Great, thanks. I’ll check it out. Since the Krea server has crashed :laughing:
Yes, you’re right, they have problems, but I also suggest Ai from D5
https://myspace.d5render.com/login?authRedirect=http%3A%2F%2Fd5next.ai%2Fhi
Guys, try https://magnific.ai/ instead of KREA
Hi Mateusshone42,
Can you show us what you did with it? A before and after comparison would be nice.
regards
