Theme: Menta kitchen
Render Artist: Ivan Alvarado
Graphics Card: RTX2070 Super
Workflow: Sketchup 2021 > D5 Render
Brief description of post-processing: None
Whether the model is original: ![]()
Model source: Login • Instagram
https://www.bmmaquetes.com/
Description of the work: Starting from a good model used for a Vray course in Portuguese (mentioned above) I wanted to put the power and characteristics of D5 Render to the test.
From SketchUp I made some slight adjustments to the model. And I added lights from the D5 plugin.
Then from D5, the first thing I did was adjust scenes, then adjust the lighting and finally adjust some materials, and I used others from the assets.
Best regards!
