I’m having a critical issue with D5 Live Sync (Cinema 4D), and it completely breaks my workflow.
Everything was working perfectly a few days ago, but now:
- Deleting objects in Cinema 4D does NOT remove them in D5
- Objects remain as “ghosts” in the scene
- I sometimes see “D5 Deconstruct” on objects
- Live Sync seems partially broken (transform works, but delete does not)
I have already tried EVERYTHING:
- Clean reinstall of D5 Render
- Clean reinstall of D5 Sync plugin
- Deleted all AppData (Local + Roaming)
- Reset D5 Launcher
- Tested on both Cinema 4D 2023 and 2024
- Created brand new scenes in both D5 and C4D
- Verified objects are truly deleted (not hidden, not in generators)
The issue persists even on a simple test:
1 cube → sync → delete → resync → cube still present in D5
This makes Live Sync unusable.
Is this a known issue with the latest version?
Is there a fix or recommended stable version?
This is blocking production work, so any help would be greatly appreciated.
Thanks
