Hi Oliver.
I still have an issue with installation this time. after installed rbz version either 0.8.3.0003 or 0.8.0004 i have note pops out every time I start SketchUp
Hi Oliver. Would you please recreate those rbz files again? probably it was something wrong with their archives
Thanks
Hi mate, sorry for that, we have escalated this issue to our dev team, and they are looking into the problem.
hello, the .rbz file for D5_Converter_SketchUp_usa_0.8.4.0004.rbz & 0.8.4.0003.rbz both doesn’t work
error shown when starting skp (2022) =
Error Loading File C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/su_to_d5render/su_to_d5render.rb
Error: #<Fiddle::DLError: unknown symbol “D5SetEntityIntProperty”>
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/su_to_d5render/su_d5_plugin_dll.rb:38:in []' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/su_to_d5render/su_d5_plugin_dll.rb:38:in module:D5dllFunc’
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/su_to_d5render/su_d5_plugin_dll.rb:13:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require’
C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/su_to_d5render/su_to_d5render.rb:2147:in <top (required)>’
C:/Program Files/SketchUp/SketchUp 2022/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2022/Tools/extensions.rb:197:in load’
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/d5_converter.rb:49:in register_extension' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/d5_converter.rb:49:in module:D5Converter’
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/d5_converter.rb:29:in `<top (required)>’
Thank you
