Custom 2d billboard feature
Is there a possibility for users to add their own 2d cutout masks to a billboard similar to the 2d people library in D5.?it would be great to have a template where one can also adjust the sizes in width and height,scale etc.so a single person and a group can be correct according to the custom size.Thank you.
I normally put a 2d person png in sketchup and than import that. Also did that for lumion. Works perfect if you want that.
Thank you.yes I can do that,but I prefer to add people in d5.I used to add my 2d people into the diffuce from the billboard,but wider and narrow content will deform.
@gerbrandts If you place a D5 2D person and use the material picker tool, you can replace with your own person png. It will also rotate with the camera and allows you to adjust scale. I have done it on past projects. You can build up your own 2D people in your local library.
