in the architectural field I have been using the CAD software EliteCAD for decades.
Therefore, I would like to have a better connection than via the export of a Sketschup file.
Bye
Andreas
Bye
Andreas
… Lumion offers a direct import from EliteCAD.
I would like to see the same between EliteCAD and D5.
Bye
Andreas
Hello, how does Lumion import EliteCAD files? It can open .dxf or .dwg format, right?
Lumion imports Sketchup files.
Unfortunately D5 imports the ones from EliteCAD
generated Sketchup files not so well, there are always missing surfaces.
The 3D data in EliteCAD, I must before the
export into a sketchup file for D5, I must make to a special part.
Which is a bit cumbersome.
Of course, it would be best that there is a
proper interface between EliteCAD and D5
would exist.
As a Christmas gift it would be nice! ![]()
Hi a.drexler,
can you tell me details how you edit the file in EliteCAD (make a special part) then the file can be opened in D5 correctly?
Also, if you can send us a sample file with problems, it will help us narrowing down the issue cause.
You can send it to support@d5techs.com
Thanks,
Oliver
As I recently learned,
the delivery of the new version 16
of EliteCAD is imminent.
It should come in the next few days.
In this new version there should also be new
Export possibilities give.
Possibly the data exchange works then
also with D5 better.
So that my problems dissolve into thin air.
I’ll wait and see.
Thanks for the offered help.
Bye
Andreas
Hello Oliver,
the problem is not gone with the new V16 of EliteCAD.
Therefore I have sent you a sample file via
e-mail.
I hope the problem in D5 will be solved in the short term.
Bye
Andreas
ok, I will check it now.
