Good afternoon, how can I resolve this issue of color BLEEDING in pool water?
The material used was water inside the D5 library and I can’t limit the bleeding.
** D5 2.7
Graphics Card: RTX4060
Workflow: Revit 2024
I’m getting the same. Some weird red lights appear everywhere only at render time. After many renderings, I discovered that reducing the water depth to .15 fixed the issue. I hope there is a fix on the next version and this info helps you.
