Hello all,
how can I change the colour of the background?
In the attached example I would like a grey instead of blue.
Bye
Andreas
Hello all,
Bye
Andreas
In the objects there is the two-dimensional plane shape, just place it and change color as you want
Thanks for the answer!
I had already done that, but the surface then receives
shadows, which is undesirable.
If you also have sketchup, then you can change the style setting for the floor to gray.
Then it should work.
I don’t use Sketchup.
Changing the background colour should work in D5.
I can only live with the following “workaround”.
I simply switched to HDRI for the lighting.
This way the background is grey and without shadows.
Bye
Andreas
As I explained before, I put the object of the plan, but I didn’t tell you how to avoid the shadows, this is because I didn’t understand it. I went on the property, and I played with the color and the illumination of the object, also giving color by removing the specularity and transparency. This is the result, I don’t know if it satisfies you, and let’s say a way to get by. I hope it will help you for the future
I’ll give it a try.
Thank you very much.
Bye
Andreas
