ok, i like d5 above. To be fair, the carona picture is a little bright, you can see the curtain and the door on the right in the back
In this 2 renders Corona looks more realistic and bright. Maybe more work on materials in D5 can make better results.
The curtains look great! May I ask where you got them and what material you applied? Did you use any special settings for the material?
May I ask what fabric you used? Did you use any special settings to change the material? I’m unable to get any of my curtains to look like that.
Thank you very much for your help. May I ask what material/color you used for the subsurface and AO? I think this is one of the missing components in my renderings. I have been leaving them blank.
Also did you use the foliage or cloth material template?
except for the settings that I showed I didn’t touch anything
Your rendering is really good. Corona is better at some things, while D5 is better at others. Corona has better curtains and wood grain. D5 has better stone flooring and lighting effects.
thanks for sharing ![]()
