If you have used 3D scanner before, you will know the texture of model export from the 3D scanner is not very well. Textures of models often go wrong when you scan. So, can I use D5 Render to render a texture on models from 3D scanner?
It depends on the model format you exported. Normally D5 can handle those models with no problem, please remember to add UV before importing them in D5 Render.
Certainly! If you’ve encountered texture issues with models exported from 3D scanner , D5 Render can be a great solution.
