Camera DOF
Hi there,
I find it hard to adjust the camera DOF to achieve satisfying blur depth effect. To see some result I need to be either too close to an object compared to the rest of the scene and/or use a very small FOV angle (ie less than 50 degrees) while having the strength to 10. It makes it very difficult to have this effect and maintain the desired framing at the same time.
FOV measuring as lens mm rather than degrees would be also very welcome.
Thanks!
I totally agree. DOF should have more usual parameters (camera-like)
