Brush density too high
Hi, is there way to further lower brush density. I have set it to the lowest value but it still produce insane amount of objects.
brush.zip (1.5 MB)
Also Undo doesn’t work here and Eraser doesn’t support fallow - it’s erase function is too harsh.
Hi @Smolak
It also depends on which asset you’ve used, if the thumbnail of the asset already shows saturated leaves, then that is under expectation.
  • The eraser tool works as a precision erase (erasing the individual asset), and there’s currently no option to soften it.
I used individual leaves for that not the grouped ones. I see that I’m not first that report this :
Brush density is too high, even at -1 - Ideas & Requests - D5 RENDER FORUM
Hi @Smolak
You can post your results in that forum link, our product team is always checking it. Thanks.
