there is not brick textures in the assets?
I suggested as well a separate category for bricks. I do a lot more exteriors than interiors and I need a lot of brick textures with different standard coursing, traditional colours, as well as modern bricks.
Yes I agree. We do alot of brick work here in north carolina, US. This would be great to have.
Hi, we have brick textures, it is under Tiles category.
Do you think we should divide them into different parts? Or could you give me some advice?
(btw, we have a secondary category in 2.0 version, any advice on our classification?)
Regards,
Oliver
Secondary category helps and is better then now. Also the addition of modern wall bricks would be good since most of the new buildings are in modern brickwork.
see link for inspiration
http://www.lookbook.heylenceramics.be/lookbook
https://www.vandemoortel.be/nl/home/
ok, thanks a lot!
one more suggestion
A favorites folder as in the “Local folder” assets
This way you can choose all of the textures as your own preferred asset library.
You should also be able to save your own special texture.
In the future solves the problem for more categories. So everyone could put together their own texture assets.
We have all our in house textures under category Masonry- which has CMU block textures and brick textures. Most all used for commercial buildings. We use these daily.
Yes having more categories is a must, or a search function.
