The quality of the rendered frames of an animation is significantly worse than a rendered image. Even the view in the editor is much better than a single frame.
You certainly want animations to be calculated very quickly. But the quality remains very poor.
Please add “High quality animation” as an option. The calculation will take significantly longer but the result should also be significantly better.
thank you in advance
