It will be great to auto-generate a Normal map from Base Color Map it will save a lot of time to recreate it separately
Hi there, thanks for your post. Actually we already have this function. When there is no map imported in the Normal map slot, there is an auto-generated Normal map although it isn’t shown in the right sidebar. You can see the effect by adjusting the Normal intensity. The change of Normal intensity still have an influence on the texture.
