Archicad sync problem
**D5 Render Version:2.7.1.0465
**Graphics Card: RTX 4070 Ti
**Driver Version: 581.08
**Issue Description: Since the last update, there has been a problem where when I want to synchronize an Archicad model with an existing d5 file, it always inserts a new model into the scene, and it does not come with the already set material settings, but with the completely raw Archicad materials. And I have to transfer all the materials to the new model with the material picker, which takes a lot of time. Every day when I restart the program and synchronize, a new model is added to the scene and I have to start the material settings from scratch.
By the way, the model live sync does not work, it updates the view, but if I change something in Archicad, it does not transfer to d5.
What can be done to solve this?
Hi @archikon
Sorry for the inconvenience caused. Could you please check whether your Archicad file has any hidden layers or duplicate model elements before syncing with D5? That can sometimes cause D5 to treat the sync as a new imported model. And is the newly added model in D5 deletable?
To help us diagnose this better, could you also send a short screen recording showing your sync process and how the new model appears?
And pease let us know your D5 Render version, your Archicad LiveSync plugin version and your Archicad version. Thank you so much!
I ran into that ‘D5 is updating’ loop too. One thing that helped me was clearing out the %temp% folder in Windows and restarting. It sounds like a generic fix, but it seems to force the plugin to check the connection properly again.
