ARCHICAD / north issue
Hello there,
I´m syncing with D5 plug in.
The geometry is turned 90 degrees in the z axis.
Meaning, in Archicad the north is set toward the top of the screen, but when imported to D5 the north is turned 90 degrees to the left.
Is this normal?
How do I fix this?
Same problem with Max.
I raised the issue and have not yet received an answer.
support?
Because D5 and UE4 consistently use a left-handed coordinate system. Both archicad and max are right-handed coordinate systems.
so it doesn´t matter where the north is pointing at, the geometry will always be turned 90 degrees to the left. It would be nice to have an option to configure this.
What drives my attention is that when using twinmotion (which is powered with UE), i don´t have this problem.
