Hi Azart
Nice work of furniture and design, I wanted to know if you use Archicad 24 or 25.
Why I use 24 again is when I synchronize my project with lights created by me with luminous material sometimes it happens that the luminating expansion of the material does not exist. I don’t know if it’s a question of archicad or the D5 program, but I don’t lose my courage, I add the lighting of D5 to have the bright environment. I wanted to know if it happens to you too, or with the latest version of archicad it doesn’t happen. Thank you
thanks . I use archicad 25 as you said, I also have a problem with lighting
@riccardofortelli @Azat Hi, can you please show me details of the problem? We will look into it as soon as possible. To confirm, this did not happen to the previous version of the plugin?
Warm greetings from China.
I think a Bag of the D5 program, because before with the previous version 2.1 I didn’t have this problem. It happened to me after opening a work in progress, I already had all the lighting of the garden and the villa, with spotlights made by me, with luminous material that gave me the lighting cone on the walls. When I opened it with the new version I didn’t have that effect but only the luminous material, I solved it by adding luminant D5. I talked about this problem with Oliver who answered me belatedly, perhaps because the users are increasing and the requests for help are many, Oliver has not exhausted my question that I have told you, it is I thought, seeing your work, if you you had the same problem. Thanks for your availability good works Azart
Hi Oliver, you were super fast
I already told you about it, but the archicad synchronizer version is 5.0. Do you think this is the problem?
Okay I’ll take a video and send it to you
Sorry Azart
I involved you in this thing, but seeing your work and knowing that you use Archicad, it came natural to ask you. Thanks, I hope it will be resolved, because when you worked on archicad, with everything, textures and lighting, you only have to make some improvements in D5 and do the rendering.
Yes, if the problem started to appear with the latest version, then the version is a problem. We will try to fix it in the next version, thanks bro
don’t worry, everything is fine)
