please add the ac 28-plugin to the download-section or at least the beta-version.
Hi there,
We usually donāt add the beta version in the official download section since it is unstable and may need more testing and optimization. If you are interested, you can check out the links that are being provided on this topic. Beta testing | D5 LiveSync for Archicad
Thank you so much.
in my opinion itās easier to use a buggy beta-plugin then a more complicated workaround. unfortunately the discord-link is already expired.
Please let us know, if there is now an approximate date for the release, or at least a functioning link to the beta version. It is very frustrating not to be able to use D5 (for me now the third new project in the last months) without degrading the Project to Archicad 27, which is not an option at my company. I have to use and pay for another rendering software, now for already three months. I would like to keep using D5 which only makes sense, if we know that it is possible to use throughout the whole year.
Any update on the Archicad 28 support? The discord beta link does not work.
Where??? please give the link
Hello @arqpatricio.bernarde
https://test.cdn.d5converter.d5techs.com/installer/Archicad_LiveSync/d989879e74d84989946af7eeeadf4fed/D5_Live_Sync_Archicad_test_1.0.0.0026.exe
Hereās the latest link and we are performing testing on Discord channel: Join Discord
Not sure how you create the invitation link but if it has x nr of uses or something but it does not work.
Hi there,
We have our discord links set at 7 days with unlimited number of use. I have tried the link and it works fine on my end. Nevertheless, I have generated another link and let me know if this works for you. D5 Render
Thank you, this one worked fine for me. ![]()
The last beta Plugin is very unstable.
1- When I try to open D5 Render inside Archicad using the palete ⦠archicad crash
2- when I close D5 Render and go back to work on archicadā¦archicad will crash
3- depending the size of the file ⦠when archicad transfer information to D5Render it crash
Hi there,
the fixed version 1.0.0.0006 has been released, please download it from our official website: D5 Render for Archicad Real-Time Rendering Workflow
Thank you for your patience and understanding.
Hi, just downloaded the D5 live sync for Archicad 28, its not working on my end, the d5 menu is not appearing and I have also checked the addons list its not there.
I apologize for the issue youāre experiencing.
To help me troubleshoot this effectively, could you please tell me:
- Have you installed any previous versions of this Archicad plugin?
- If so, please check for any remaining files or settings from the previous installation, as these can sometimes cause conflicts.
- Was the installation of the current plugin successful?
- If the installation was successful but you canāt find the plugin within Archicad, try right-clicking on the toolbar. This might help you locate and activate the plugin.
- Please ensure that you also have admin rights of the installation folder.
Please let me know if any of these suggestions helped, thank you.
Thanks for your reply, I have double checked on my side and notice that the location for addons directory was pointed in a different addon now that I have changed it everything works fine! Thanks again!
