I was trying to apply surface imperfections like swipe marks on the glass surface/ mirror, but it doesn’t work. When I tried on custom material with full metallic, it worked. I wanted to create swipe marks on transparent glass. and also, the applied decal is doesn’t stick to the surface applied, but rather gets painted all over the surface in front of the decal, which is quite annoying. How can this be fixed? Please, Help!
Not exactly the solution for me, but thank you, and what about the decal is not sticking to the surface applied, but rather gets painted all surfaces that is in front of the decal.
Maybe, I don’t understand, the sticker is those scratches above the mirror?
Because you can apply the imperfection on the AO image like the mirror I showed you.
This is if you have the AO sticker image
Eventually you have to substitute PBR textures on that material
I hope I understand the problem
The program that makes you PBR is:
Hi mate, it’s not supported now, you have to make another model of decals in front of your glasses. Thank you for your advice, we will consider to improve it.
Plus one for this request. Decals would be a great feature for window film or when a wall graphic is applied to a solid surface and window.
