It would be great if D5Render had the option of configuring the size of the textures using the actual unit in meters.
Even better if you had the option of sliding the origin position using a buzzer.
Thanks
Hi, thanks for the suggestions. For parameters in the left sidebar, we can double click to let them return to the default. But for the asset’s parameters, we have not applied an option as you mentioned. I will deliver these two requests to the product team via Trello.
Regards,
Oliver
