Hi. When exporting from 3ds max to D5 render I have this issue in which some object from 3ds max has mask Map (you can find an example in the attachment file ). So please consider adding a Mask map with separate material or color inside Base Color Map
Hi there, thanks for your advice! We’ve received it and sent it to our team.
