3ds Max converting Porblem
Hi, every time I convert a 3ds max file to d5 format all object (layers) becomes one object in d5 render.
For example in 3ds max, I have a simple building with
  1. wall
  2. roof
  3. doors
  4. others
Once I convert it and open it on d5 render it all becomes one object. If I select it, it will select all as one object.
How to fix this?
Hi there,
Please check if you have install vray, and make sure they’re vray materials.
DO I have to give each object a different vray material first on 3dsmax? because what i want is to work on5d rendering with the material mapping
If you want to apply material mapping in D5, just give each object with a different material name, and import to D5 by D5 Converter.
