Has anyone else had issues with D5 when syncing with a Revit model since upgrading to 2.11? Everything was working fine for me on 2.10, but after trying to install 2.11 and the newer Revit sync plug-in, every time I try to sync my project from Revit my D5 crashes. I’ve emailed support, but was curious if anyone else is experiencing the same issue.
Hi @jacob
Which Revit Version are you using? Can you perhaps send to us your revit file so we can test it?
- Please send it to support@d5techs.com and have it titled 2.11 Clov-Forum Everyime I try to Sync My Project from Revit D5 Crashes
Let me know if you have sent it already.
Hey Clov, sorry just seeing this. I’m sending you the info now.
I have had this problem with multiple projects in 2.11. The workaround that I have found is to hide the Revit model in D5 and then refresh the link
Yes. It is the latest Revit plug-in
