193 RAL Classic wall Paint
hello to all.
I want to share with you my library of RAL materials for D5.
193 RAL Classic.
From the link you can find folders:
  • RAL category. Folder that you must put in the path …/library/material
  • Palette. Folder that contains the 193 RAL colors 4k png
  • Map. Folder with the 4K maps for Normal and Specular
In the folder RAL category you have only one RAL material (RAL_1000_Green_beige). Just replace the png map with the desired one in the Palette folder. Creating 193 materials takes a lot of space in our HD/SSD/M2. More convenient to have only one RAL material and change the color map.
Good work to all
https://drive.google.com/drive/folders/1gevO_nNpWm6jJE2_vcEmwnsY5hdZg3kv?usp=sharing
Thank you very much . :grinning:
:clap: Wow, I just saw this topic, thank u very much Gianluca
Thank you very much for your generosity!
These will definitely make things easier and more correct :slightly_smiling_face: :+1: :+1:
I’m happy to see it, hope to integrate more and more colors like this :
https://shadereditor.gumroad.com/l/ral-colours
huss191998:
sure. ^_-
Thank you very much . :+1: :muscle: :pray:
Thanks for sharing. What are the material dimensions?
Allenm … material dimension in 4k
Hello. Yes. The resolution is 4K. I’m referring to the physical size. Like 2 meters x 2 meters, 3 m x 3 m. Etc. physical size is important for proper scaling, seaming, and so on.
physical size … ok ok
all maps are seamless
from my tests 2m x 2m … maximum 3 x 3m
Thank you so much for sharing! Great texture <3
Thank for sharing!
can u make a video explaining the steps? I’m beginner :frowning:
Ok, no problem. :wink:
Thank you so much!
thank you for this beautiful work and sharing, it was very useful to me
Thank you! :pray:
